Can WSWIN Data export start time set to xx:00
wfpost
Post by wfpost »
I installed WSWIN and used meteohub´s WSWIN Data export feature to create easy to setup graphs and sheets.
Works fine, but one thing I do not get to work.
Using the "Generate WSWIN Data ongoing" function, WSWIN exports all the data without any problems, but the start time for the current.html is always at minute 7,17,27, ...
When pressing the Synch Reset button again, everything still starts at minute 7,17,27, ...
I tried the offset settings of WSWIN, but it does not help either.
What can I do to start data at xx:00 or xx:10 xx:20, ... ??
What´s so magic with the seven? ;)
http://www.myway.de/honsolgen/current.html
http://www.myway.de/honsolgen/wswina.html
