Multiple restarts services in MB PRO in Meteoplug server falldown
agallardo1980
Post by agallardo1980 »
This past night, the MeteoPlug server was falldown (CONNECTION TIMED OUT) from 1:15-7:20
2019-03-06 08:09:52 Success: 2019-03-06 08:09:50
2019-03-06 07:20:12 Error: 2019-03-06 07:19:44  (no more tries)
2019-03-06 07:10:10 Error: 2019-03-06 07:09:42 Read error (Connection timed out) in headers.  (no more tries)
2019-03-06 01:46:54 Error: 2019-03-06 01:46:29  (no more tries)
2019-03-06 01:36:56 Error: 2019-03-06 01:36:28  (no more tries)
2019-03-06 01:26:53 Error: 2019-03-06 01:26:26  (no more tries)
2019-03-06 01:16:52 Error: 2019-03-06 01:16:25  (no more tries)
2019-03-06 01:06:27 Success: 2019-03-06 01:06:25
The problem was that this affected to stability of Meteobridge PRO. There was several automatic service restarts and I lost several tips from rain gauge (exactly 3 tips, 0,6mm). Below this message, I attach the log and images about rain total in Console, WL.com and MB_PRO.
Please Boris: is any form to fix this so Meteoplug server issues does not affect to Meteobridge PRO? I think it is very important because it affects to the quality of weather station data.
Other question: I lost one hour of data in Meoteoplug (5:00-6:45). Is it possible export data from MB to import in MeteoPlug?
I await your response. Thank you very much.
logger (06.03.2019 05:16:46): databases connected. Update interval 3600 seconds.
logger (06.03.2019 05:16:46): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 05:16:46): error while doing bind (port 22222): Address already in use
logger (06.03.2019 05:16:46): killed process "2419/sh" listening to port 22222.
logger (06.03.2019 05:17:16): databases connected. Update interval 3600 seconds.
logger (06.03.2019 05:17:16): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 05:17:16): error while doing bind (port 22222): Address already in use
logger (06.03.2019 05:17:16): killed process "2420/meteosys" listening to port 22222.
logger (06.03.2019 05:17:46): databases connected. Update interval 3600 seconds.
logger (06.03.2019 05:17:46): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 05:17:47): connect station 0 (Vantage via TCP/IP).
logger (06.03.2019 05:17:47): connect station 9 (System Data via Plug-in).
logger (06.03.2019 05:17:47): wakeup sent.
logger (06.03.2019 05:17:50): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2019 05:17:50): services paused.
logger (06.03.2019 05:17:50): no need to update console date/time.
logger (06.03.2019 05:17:50): setup script executed.
logger (06.03.2019 05:17:50): internal logger activated.
logger (06.03.2019 05:17:50): syncing.
logger (06.03.2019 05:18:01): gettime request sent.
logger (06.03.2019 05:18:01): no Vantage time offset.
logger (06.03.2019 05:18:01): eeprom request sent.
logger (06.03.2019 05:18:02): rain collector size 0.2 mm per tick.
logger (06.03.2019 05:18:02): transmitter 1 active as station type #0 "ISS".
logger (06.03.2019 05:18:02): firmware version request sent.
logger (06.03.2019 05:18:02): firmware version 3.80 (supports LOOP2)
logger (06.03.2019 05:18:02): no reading of Vantage's internal logger.
logger (06.03.2019 05:18:07): sensors are now providing data.
logger (06.03.2019 05:18:07): services started.
logger (06.03.2019 05:37:54): error writing logged data to pipe "gzip >/var/run/meteohub/inetupload.z": Bad file descriptor
logger (06.03.2019 05:47:57): message above repeats 1 time.
logger (06.03.2019 06:38:27): child process received timeout signal (14).
logger (06.03.2019 06:38:27): disconnect station 0 (Vantage): exit
logger (06.03.2019 06:38:27): disconnect station 9 (System Data): exit
logger (06.03.2019 06:38:30): data logger stopped.
logger (06.03.2019 06:38:30): databases disconnected.
logger (06.03.2019 06:38:30): databases connected. Update interval 3600 seconds.
logger (06.03.2019 06:38:30): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 06:38:31): connect station 0 (Vantage via TCP/IP).
logger (06.03.2019 06:38:31): connect station 9 (System Data via Plug-in).
logger (06.03.2019 06:38:31): wakeup sent.
logger (06.03.2019 06:38:34): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2019 06:38:34): services paused.
logger (06.03.2019 06:38:34): no need to update console date/time.
logger (06.03.2019 06:38:35): setup script executed.
logger (06.03.2019 06:38:35): internal logger activated.
logger (06.03.2019 06:38:35): syncing.
logger (06.03.2019 06:38:45): gettime request sent.
logger (06.03.2019 06:38:45): no Vantage time offset.
logger (06.03.2019 06:38:45): eeprom request sent.
logger (06.03.2019 06:38:46): rain collector size 0.2 mm per tick.
logger (06.03.2019 06:38:46): transmitter 1 active as station type #0 "ISS".
logger (06.03.2019 06:38:46): firmware version request sent.
logger (06.03.2019 06:38:46): firmware version 3.80 (supports LOOP2)
logger (06.03.2019 06:38:46): no reading of Vantage's internal logger.
logger (06.03.2019 06:38:51): sensors are now providing data.
logger (06.03.2019 06:38:51): services started.
logger (06.03.2019 07:08:36): databases connected. Update interval 3600 seconds.
logger (06.03.2019 07:08:36): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 07:08:36): error while doing bind (port 22222): Address already in use
logger (06.03.2019 07:08:36): killed process "17731/sh" listening to port 22222.
logger (06.03.2019 07:09:06): databases connected. Update interval 3600 seconds.
logger (06.03.2019 07:09:06): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 07:09:06): error while doing bind (port 22222): Address already in use
logger (06.03.2019 07:09:06): killed process "17732/meteosys" listening to port 22222.
logger (06.03.2019 07:09:36): databases connected. Update interval 3600 seconds.
logger (06.03.2019 07:09:36): data logger (version 5.1a, build 12713) started.
logger (06.03.2019 07:09:37): connect station 0 (Vantage via TCP/IP).
logger (06.03.2019 07:09:37): connect station 9 (System Data via Plug-in).
logger (06.03.2019 07:09:37): wakeup sent.
logger (06.03.2019 07:09:40): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (06.03.2019 07:09:40): services paused.
logger (06.03.2019 07:09:49): execution of setup script failed (console is not responding).
logger (06.03.2019 07:09:49): internal logger activated.
logger (06.03.2019 07:09:49): syncing.
logger (06.03.2019 07:09:49): gettime request sent.
logger (06.03.2019 07:09:49): communication with Davis console/envoy seems to be stalled. Please power cycle the console/envoy by (1) disconnect from AC, (2) remove batteries and (3) disconnect USB. Wait a minute and power on again. Weak batteries need to be replaced.
logger (06.03.2019 07:09:59): gettime request sent.
logger (06.03.2019 07:10:09): message above repeats 1 time.
logger (06.03.2019 07:10:19): execution of setup script failed (console is not responding).
logger (06.03.2019 07:10:19): internal logger activated.
logger (06.03.2019 07:10:19): syncing.
logger (06.03.2019 07:10:19): gettime request sent.
logger (06.03.2019 07:10:19): no Vantage time offset.
logger (06.03.2019 07:10:19): eeprom request sent.
logger (06.03.2019 07:10:20): rain collector size 0.2 mm per tick.
logger (06.03.2019 07:10:20): transmitter 1 active as station type #0 "ISS".
logger (06.03.2019 07:10:20): firmware version request sent.
logger (06.03.2019 07:10:21): firmware version 3.80 (supports LOOP2)
logger (06.03.2019 07:10:21): no reading of Vantage's internal logger.
logger (06.03.2019 07:10:27): sensors are now providing data.
logger (06.03.2019 07:10:27): services started.
logger (06.03.2019 07:29:42): error writing logged data to pipe "gzip >/var/run/meteohub/inetupload.z": Bad file descriptor
logger (06.03.2019 07:59:48): message above repeats 3 times.
Re: Multiple restarts services in MB PRO in Meteoplug server falldown
I will have a look if the meteoplug server outage does really block anything of the MB PRO. It should not of course.
There is no automated import of Meteobridge data to Meteoplug. Meteoplug import format is defined and documented, so you can setup a few rain records manually and import that.
