Davis [forecast-text] variable for Spanish
agallardo1980
Post by agallardo1980 »
Hi.
Boris: If you want, I could to translate to Spanish all text in [forecast-text] and and so it can be used for Spanish MB users. If so, send me the texts in English and proceed with the translation.
Re: Davis [forecast-text] variable for Spanish
OK, please see attached. I would need it in HTML encoding:
char *vantage_fc_rule[] = {
  "Mostly clear and cooler."
, "Mostly clear with little temperature change."
, "Mostly clear for 12 hours with little temperature change."
, "Mostly clear for 12 to 24 hours and cooler."
, "Partly cloudy and cooler."
, "Partly cloudy with little temperature change."
, "Mostly clear and warmer."
, "Increasing clouds and warmer. Precipitation possible within 24 to 48 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 24 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 12 hours."
, "Increasing clouds and warmer. Precipitation possible within 24 hours."
, "Mostly clear and warmer. Increasing winds."
, "Increasing clouds and warmer. Precipitation possible within 12 hours. Increasing winds."
, "Increasing clouds and warmer."
, "Mostly clear and warmer. Precipitation possible within 48 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 24 to 48 hours."
, "Increasing clouds with little temperature change."
, "Increasing clouds and warmer. Precipitation possible within 12 to 24 hours."
, "Increasing clouds and warmer. Precipitation possible within 12 to 24 hours. Windy."
, "Increasing clouds and warmer. Precipitation possible within 6 to 12 hours."
, "Increasing clouds and warmer. Precipitation possible within 6 to 12 hours. Windy."
, "Increasing clouds and warmer. Precipitation possible within 12 hours."
, "Increasing clouds and warmer. Precipitation likely."
, "Clearing and cooler. Precipitation ending within 6 hours."
, "Mostly clear and cooler."
, "Mostly cloudy and cooler. Precipitation continuing."
, "Mostly cloudy and cooler. Precipitation likely."
, "Mostly cloudy with little temperature change. Precipitation continuing."
, "Mostly cloudy with little temperature change. Precipitation likely."
, "Increasing clouds and cooler. Precipitation possible and windy within 6 hours."
, "Increasing clouds with little temperature change. Precipitation possible and windy within 6 hours."
, "Mostly cloudy and cooler. Precipitation continuing. Increasing winds."
, "Mostly cloudy and cooler. Precipitation likely. Increasing winds."
, "Mostly cloudy with little temperature change. Precipitation continuing. Increasing winds."
, "Mostly cloudy with little temperature change. Precipitation likely. Increasing winds."
, "Increasing clouds and cooler. Precipitation possible within 12 to 24 hours possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hours possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 6 hours possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation ending within 12 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation ending within 12 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 24 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 24 hours possible wind shift to the W, NW, or N."
, "Clearing, cooler and windy. Precipitation ending within 6 hours."
, "Clearing, cooler and windy."
, "Mostly cloudy and cooler. Precipitation ending within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 12 hours. Windy."
, "Increasing clouds and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation ending within 6 hours. Windy."
, "Mostly cloudy and cooler. Precipitation possible within 12 hours. Windy."
, "Mostly cloudy and cooler. Precipitation ending in 12 to 24 hours."
, "Mostly cloudy and cooler."
, "Mostly cloudy and cooler. Precipitation continuing, possible heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hours. Windy."
, "Mostly cloudy with little temperature change. Precipitation continuing, possibly heavy at times. Windy."
, "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hours. Windy."
, "Increasing clouds with little temperature change. Precipitation possible within 12 hours, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Windy."
, "Mostly cloudy and cooler. Precipitation continuing, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation likely, possibly heavy at times. Windy."
, "Mostly cloudy with little temperature change. Precipitation likely, possibly heavy at times. Windy."
, "Increasing clouds and cooler. Precipitation possible within 6 hours. Windy."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours. Windy"
, "Increasing clouds and cooler. Precipitation continuing. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation likely. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation continuing. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation likely. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 12 to 24 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possibly heavy at times and ending within 12 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hours, possibly heavy at times. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation ending within 12 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hours, possibly heavy at times. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy.", "FORECAST REQUIRES 3 HOURS OF RECENT DATA"
agallardo1980
Thanks Boris,
Here translate HTML coding code:
  "Mayormente despejado y más frio."
, "Mayormente despejado con ligeros cambios de temperatura."
, "Mayormente despejado durante 12 horas con ligeros cambios de temperatura."
, "Mayormente despejado durante 12 a 24 horas y más frio."
, "Parcialmente nuboso y más frio."
, "Parcialmente nuboso con ligeros cambios de temperatura."
, "Mayormente despejado y más cálido."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 24 a 48 horas."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 24 horas."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 12 horas."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 24 horas."
, "Mayormente despejado y más cálido. Vientos en aumento."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 12 horas. Vientos en aumento."
, "Nubes en evolución y más cálido."
, "Mayormente despejado y más cálido. Precipitación posible dentro de 48 horas."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 24 a 48 horas."
, "Nubes en evolución con ligeros cambios de temperatura."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 12 a 24 horas."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 12 a 24 horas. Ventoso."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 6 a 12 horas."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 6 a 12 horas. Ventoso."
, "Nubes en evolución y más cálido. Precipitación posible dentro de 12 horas."
, "Nubes en evolución y más cálido. Precipitación probable."
, "Despej&aactute;ndose y más frio. Precipitación termina dentro de 6 horas."
, "Mayormente despejado y más frio."
, "Mayormente nublado y más frio. Precipitación continúa."
, "Mayormente nublado y más frio. Precipitación probable."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación continúa."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación probable."
, "Nubes en evolución y más frio. Precipitación posible y ventoso dentro de 6 horas."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible y ventoso dentro de 6 horas."
, "Mayormente nublado y más frio. Precipitación continúa. Vientos en aumento."
, "Mayormente nublado y más frio. Precipitación probable. Vientos en aumento."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación continúa. Vientos en aumento."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación probable. Vientos en aumento."
, "Nubes en evolución y más frio. Precipitación posible dentro de 12 a 24 horas posible cambio de viento al O, NO, o N."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 12 a 24 horas posible cambio de viento al O, NO, o N."
, "Nubes en evolución y más frio. Precipitación posible dentro de 6 horas posible cambio de viento al O, NO, o N."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 6 horas posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Precipitación termina dentro de 12 horas posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación termina dentro de 12 horas posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Precipitación posible dentro de 24 horas posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación posible dentro de 24 horas posible cambio de viento al O, NO, o N."
, "Despej&aactute;ndose, más frio y ventoso. Precipitación termina dentro de 6 horas."
, "Despej&aactute;ndose, más frio y ventoso."
, "Mayormente nublado y más frio. Precipitación termina dentro de 6 horas. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación posible dentro de 12 horas. Ventoso."
, "Nubes en evolución y más frio. Precipitación posible dentro de 12 horas, posiblemente intensa por momentos. Ventoso."
, "Mayormente nublado y más frio. Precipitación termina dentro de 6 horas. Ventoso."
, "Mayormente nublado y más frio. Precipitación posible dentro de 12 horas. Ventoso."
, "Mayormente nublado y más frio. Precipitación termina en 12 a 24 horas."
, "Mayormente nublado y más frio."
, "Mayormente nublado y más frio. Precipitación continúa, posiblemente intensa por momentos. Ventoso."
, "Mayormente nublado y más frio. Precipitación posible dentro de 6 a 12 horas. Ventoso."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación continúa, posiblemente intensa por momentos. Ventoso."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación posible dentro de 6 a 12 horas. Ventoso."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 12 horas, posiblemente intensa por momentos. Ventoso."
, "Mayormente nublado y más frio. Ventoso."
, "Mayormente nublado y más frio. Precipitación probable, posiblemente intensa por momentos. Ventoso."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación probable, posiblemente intensa por momentos. Ventoso."
, "Nubes en evolución y más frio. Precipitación posible dentro de 6 horas. Ventoso."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 6 horas. Ventoso"
, "Nubes en evolución y más frio. Precipitación continúa. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Precipitación probable. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación continúa. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación probable. Ventoso con posible cambio de viento al O, NO, o N."
, "Nubes en evolución y más frio. Precipitación posible dentro de 6 horas. Ventoso con posible cambio de viento al O, NO, o N."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 6 horas. Ventoso con posible cambio de viento al O, NO, o N."
, "Nubes en evolución y más frio. Precipitación posible dentro de 12 a 24 horas. Ventoso con posible cambio de viento al O, NO, o N."
, "Nubes en evolución con ligeros cambios de temperatura. Precipitación posible dentro de 12 a 24 horas. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Precipitation posiblemente intensa por momentos y termina dentro de 12 horas. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Precipitación posible dentro de 6 a 12 horas, posiblemente intensa por momentos. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación termina dentro de 12 horas. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado con ligeros cambios de temperatura. Precipitación posible dentro de 6 a 12 horas, posiblemente intensa por momentos. Ventoso con posible cambio de viento al O, NO, o N."
, "Mayormente nublado y más frio. Precipitación posible dentro de 12 horas, posiblemente intensa por momentos. Ventoso.", "PRONÓSTICO REQUIERE 3 HORAS DE DATOS RECIENTES"
thanks, will be part of the next update.
Just released as "texteshtml".
When you also need it also in UTF-8 or ISO, I am happy to include this as well.
agallardo1980
Thank you very much :)
