How to get MBP to see UV and Solar sensors on a Davis Anemometer Transmitter Kit
seaman55
Post by seaman55 »
I have a Davis VP2 ISS in my back yard, using ID#3 for now, and a Davis Anemometer Transmitter Kit on the roof with and Anemometer, UV and Solar sensor attached using ID#1.
How do I tell the MB Pro to us ID#1 for Wind and Solar/UV sensors?
Right now I am accomplishing this by using this relay device solution;
https://cumulus.hosiene.co.uk/viewtopic ... b&start=15
But I figure the Meteobridge PRO should be able to do it internally, and I can then remove my relay.
Re: How to get MBP to see UV and Solar sensors on a Davis Anemometer Transmitter Kit
Define both as ISS and pick on Live data page which of the sensors should be used as primary.
seaman55
Post by seaman55 »
Wow, never noticed that option before.
Thank you.
Giving that a try now.
