Moving white vertical lines **solved**
woolfg
Post by woolfg »
Hi
I have just received a Meteobridge PRO today which I am in the process of setting up
I think I have configure it correctly but every few seconds the screen display shows two vertical white lines slowly moving towards the centre
Is this normal and what is the unit doing - if not what is causing it
Many Thanks
Graham
Ag2000CO
Re: Moving white vertical lines
Post by Ag2000CO »
Yes that is the normal "screen saver" action
Lou
You can find a reference to this on http://www.meteobridge.com/wiki/index.php/Forum see Version 3.2 May 26, 2017
woolfg
Re: Moving white vertical lines **solved**
Post by woolfg »
Mny thanks for the replies
Graham
