Write to influxdb
pacsabi
Write to influxdb
Post by pacsabi »
I'm collecting all my home IoT data in influxdb. Is there any method to export sensor data from meteobridge to a local influxdb?
Like this: curl -i -XPOST 'http://localhost:8086/write?db=mydb' --data-binary 'cpu_load_short,host=server01,region=us-west value=0.64 1434055562000000000'
Re: Write to influxdb
curl is not available on Meteobridge. I would recommend to install a web server on your data base server that is fed via Meteobridge by HTTP get requests with the data as URL parameter. The so triggered script then does the magic on your server to bring data into your database.
pacsabi
Post by pacsabi »
Great idea, many thanks!
