Meteobridge Pro wind display on front panel
woolfg
Post by woolfg »
Hi
At the moment I have a scrolling display showing temp, pressure rain etc but the wind units are showing in kilometers but my Davis is set for wind in knots
Is there any way to get the Meteobridge Pro to show wind speed in knots
Graham
Re: Meteobridge Pro wind display on front panel
Yes, you will have to design your own display script. You can start reading here:
https://www.meteobridge.com/wiki/index.php/PRO_Display
woolfg
Post by woolfg »
Hi
Thanks for the reply . Does it have to be a new script or can I just change the units in the existing one. Im using BIG-scroll-ISO.dsp in the templates directory
Graham
What you would do is make a copy of the existing one, rename the copy to whatever name suits you and modify as you require
