Meteobridge Nano SD: Station Altitude
i am a new user with Davis Vantage Vue and Nano SD.
In the Local Settings is the option Station Altitude. Must i set this parameter additionally, if i already set the parameter in the Davis console?
On Weather Underground in the station config, is also a config for Station Altitude. Works the weather networks with the raw data or are then wrong data?
Torsten
SANdood
Re: Meteobridge Nano SD: Station Altitude
Post by SANdood »
I suggest that you input the exact same Altitude and Lat/Lon coordinates into your Davis station, your Meteobridge, and on Weather Underground. And on any other weather site you upload your information to.
This will enable access to the data no matter what application or API you use. Altitude is necessary to calculate the sea-level barometric pressure, among other things.
FWIW, I set the Meteobridge Alt/Lat/Lon/Timezone/Rain season values, and then have it update the Davis so that both have the exact same values...
ok i set in Station and Meteobridge the same value
Thanks :D
