WSWIN data-feed template not found **solved**
Micha999
Post by Micha999 »
Can't open the WSWIN data-feed. Error-Message means: cannot open template file: /tmp/mnt/data/templates/.wswin.exp
I'm using the actual meteobrige-nano version: Meteobridge 3.9 (Apr 7 2019, build 2032)
Does anybody can tell me, where to download the template-file or give me a hint, what to do?
Thank you
Micha
Re: WSWIN data-feed template not found
Micha999
Post by Micha999 »
I hope, I understand your suggestions.
Yes, I did read . But it's not a problem of importing WSWIN-files. That works fine.
It's a problem of generating an export file for WSWIN like: "import.csv". I think it's the same structure (or similar) like in meteohub.
I don't have any background re Meteohub but there should be a range of .exp files in the mb-nano template directory? There should be a wswin-monthly.exp plus at least another 10 other export template files?
Have you looked in \\your.mb.nano.ip\data\templates for .exp files?
Micha999
Post by Micha999 »
Yes, all files are in. Even the "wswin-monthly.exp". But the wswin.exp is missing. Don't know why. Perhaps it's a hidden file because of the dot. I'm not a linux specialist :D
Just looked into some MB & Nano systems, wswin.exp does not exist in either. Would wswin.exp be something particular to Meteohub only?
Micha999
Post by Micha999 »
I don't think so.
It's an option in the drop-down list and it's a system error-message. I think it must be a "real" file in meteobridge-nano.
Bildschirmfoto 2019-04-11 um 07.19.20.png (291.58 KiB) Viewed 2580 times
Bildschirmfoto 2019-04-11 um 07.17.56.png (497.53 KiB) Viewed 2580 times
Thanks for spottig this. The file is missing on the NANO SD. The just release update has this fixed.
