Cannot install 2.5a on 2.5 ** solved **
najbo
Post by najbo »
Hi !
I can't install 2.5a on my 2.5 version (using file software update).
System reboots but remains at 2.5.
Here's a strange smb log :
[2008/07/08 06:35:25, 0] lib/util_sock.c:get_peer_addr(1229)
getpeername failed. Error was Transport endpoint is not connected
[2008/07/08 06:35:25, 0] lib/util_sock.c:write_data(562)
write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
[2008/07/08 06:35:25, 0] lib/util_sock.c:send_smb(769)
Error writing 4 bytes to client. -1. (Connection reset by peer)
[2008/07/08 06:35:29, 1] smbd/service.c:make_connection_snum(941)
aval (192.168.0.xx) connect to service public initially as user root (uid=0, gid=0) (pid 6038)
[2008/07/08 06:38:03, 1] smbd/service.c:close_cnum(1141)
aval (192.168.0.xx) closed connection to service public
[2008/07/08 06:39:03, 0] smbd/server.c:main(881)
standard input is not a socket, assuming -D option
[2008/07/08 06:39:03, 1] lib/account_pol.c:account_policy_get(329)
account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0
[2008/07/08 06:46:08, 0] smbd/server.c:main(881)
[2008/07/08 06:46:09, 1] lib/account_pol.c:account_policy_get(329)
[2008/07/08 06:49:04, 0] smbd/server.c:main(881)
[2008/07/08 06:49:04, 1] lib/account_pol.c:account_policy_get(329)
[2008/07/08 06:49:05, 1] lib/account_pol.c:account_policy_get(329)
Re:Cannot install 2.5a on 2.5
go with 2.5d.
najbo
Post by najbo »
Thank you Boris, it worked !
