Just so that everyone understands the significance of this. If you own a Fine Offset clone station. That is you have a station brand that is Ambient Weather, Ecowitt, Tycon, Aercus, Watson, Misol, Froggit, Maplin, Conrad...etc. Then you can use this GW1000 WiFi console. You can keep using your existing console too.
If your station looks like any of these, then the GW1000 (with the matching frequency) will work:
- Fine Offset Outdoor Sensor Array.png (175.49 KiB) Viewed 7270 times
All you need to do is get a GW1000 with the matching frequency for your station. Your frequency will be 433 MHz, 915 MHz, or 868 MHz. After you know your frequency then you can order the correct version of the GW1000 now from Ecowitt. They will send you a GW1000 with whichever frequency you need.
This is truly a worthy upgrade.
