Antenna on Meteobridge NANO SD
meteofabro
Post by meteofabro »
Hello.
I would like to know if it is possible to install an external antenna on the IPX connector of the NANO SD?
Re: Antenna on Meteobridge NANO SD
No, external antenna connector is disabled in firmware.
Why? Can a external antenna not help?
I have problems with the Wlan from Nano SD. The system log frequently on a day „Disconnected from WLAN or Internet, reconnect issued.“
The Davis Console is placed 3m from Fritzbox 7590.
This is presumably not a WLAN problem, but might be something about the Internet connection or slow DNS. However, don't be alarmed by the messages, it just tells you that Meteobridge does rebuild WLAN/Internet connection to make sure it does not run into problems. I may add the phrase "DON'T PANIC" to the message ;-)
Thanks for your answer :wink:
