Full support for Ambient Weather PM2.5 sensor in the works? **solved**
michaeljwestii
Post by michaeljwestii »
Thanks for adding support for the AW PM2.5 sensor and supporting data uploads to WU and AW, I see mine on the live data tab and that is good. Any chance you can also update the Meteotemplate support, so the data is sent there also?
thx
Mike
Re: Full support for Ambient Weather PM2.5 sensor in the works?
Is added in just released update.
michaeljwestii
The release notes specifically say WU and AW and no other services. If it is uploaded to all services why doesn't the release notes say that? I am not seeing the data uploaded to Meteotemplate for posting to my SQL database, so since the release notes do not say you have implemented that and Meteotemplate doesn't see it, all I can say is it looks like you haven't implemented full support, or you did but it is broken.
I think I also added it to Meteotemplate. Don't you get the data there?
Only very few networks take air quality data, therefore I mentioned the ones having a benefit from this new sensor type.
michaeljwestii
Re: Full support for Ambient Weather PM2.5 sensor in the works? **solved**
Thanks, when I check my Meteotemplatelive file which shows the data being imported, it does not show up.
{"U":1559094891,"SW":"meteobridge","T":17.4,"TMX":17.4,"TMN":17.4,"H":94,"P":1005.5,"W":1.3,"G":3.6,"B":281,"R":8.1,"RR":0,"S":0,"UV":0,"TIN":21.4,"HIN":65,"UTime":1559094894,"SWTime":1559094894,"TTime":1559094894,"TMXTime":1559094894,"TMNTime":1559094894,"HTime":1559094894,"PTime":1559094894,"WTime":1559094894,"GTime":1559094894,"BTime":1559094894,"RTime":1559094894,"RRTime":1559094894,"STime":1559094894,"UVTime":1559094894,"TINTime":1559094894,"HINTime":1559094894,"D":16.4,"DTime":1559094894,"A":19.3,"ATime":1559094894}
I am also posting on the Meteotemplate forum, maybe there is something that needs to be adjusted on the api.php file for it to show up.
This really isn't solved.
thx
Mike
Does the sensor show up as "air0pm" on your live data tab?
michaeljwestii
Sorry for the delay. The display is kind of confusing, the top area for Live Data says "Air", but down below on the historical data table the display says "Air pm" but mouseover says "Air0pm", so maybe?
"Air" with a capital "A"? I would expect small letters like "air0pm".
