Page 1 of 2
Problems with the WLAN at Meteobridge NANO SD
Posted: Thu Jun 06, 2019 10:15 pm
by tofe
Good evening from Switzerland
I've already successfully deployed a Meteobridge PRO, a Meteobridge NANO (in a console) and a Meteobridge NANO SD (in a console).
For a week I have a Meteobridge NANO SD (in an Envoy, red cable, with 1A power supply, SD card was included in the purchase) and I have problems from the beginning with the wireless. I have already removed the batteries many times and removed the power supply and waited 5 minutes. Total I have already made 5 Reset (5x flashing).
The problem is that the fixed assigned IP address (definitely unique address), partially not saved and the network name meteobridge is displayed. Then it is only possible to log in via the meteobridge WLAN (192.168.169.1). After some time, the log in works on the fixed IP, the meteobridge WLAN is no longer displayed. Later, the Meteobridge NANO SD can not be reached via fixed IP or meteobridge WLAN. If it was reachable and logging in, the Wi-Fi connection was very slow, at least 10 times slower than any other Meteobridges available.
The LED is constantly red. The software I once had the 4.0 of 01.06.2019, but also the last of 3.9, always the same behavior.
Currently, the Meteobridge NANO SD is no longer available, either from the fixed IP or the metobridge WLAN.
Is this a hardware problem?
Thank you very much for your help.
Tobias
Re: Problems with the WLAN at Meteobridge NANO SD
Posted: Fri Jun 07, 2019 1:09 am
by ConligWX
The Meteobridge WLAN is disabled after 15 minutes of Internet connectivity.
ie: once the Nano picks up a DHCP assigned IP address on your LAN and it does a test every 5 minutes to check if an external website is available the WLAN is then disabled.
if the internet site cannot be contacted then it re-enables the WLAN again.
If you cannot contact the NANO with the assigned address, then there is something wrong with DHCP.
can you confirm you have a static assigned address to the NANO (via your DHCP server) that is outside of the DHCP scope but using the same network address range and subnet.
or have you manually assigned one in the Meteobridge Webgui. if it is in the GUI, then you have most likely assigned the ip address incorrectly or gateway/subnet is incorrect.
you will most likely need to restart the nano manually. connect to the Nano WLAN, disable Static IP, and let DHCP assign the ip/network addressing.
Posted: Fri Jun 07, 2019 11:17 pm
by tofe
Good evening simon
Thank you very much for your detailed answer.
The first couple of hours, the meteobridge NANO SD is reached via the static IP, then suddenly not more. When I remove the power cord and the batteries, wait a short time and then connect again, restart the meteobridge NANO SD and can be reached again for a few hours via static IP. However, the connection is very, very slow compared to the other meteobrests I've been using.
Even if it is no longer accessible via static IP, the data is uploaded as defined via FTP to my server. Pingbar is the NANO SD sometimes, sometimes not.
What could be this behavior, what can I do about it?
Greetings and best thanks
Tobias
Posted: Sat Jun 08, 2019 4:21 am
by ConligWX
Hi Tobias
have you many WiFi devices on you network? is there good signal strength to the Nano ? Anything that maybe interfering with the signal? have you tried changing channels. 1, 6 and 11 (or 13) are preferable. you may have other neighbouring WiFi networks that are affecting your own WiFi signal?
do you have many Services running on the Nano? maybe the CPU is overloaded? how many entries do you have?
I have 17 entries of Services, and 10 Weather Networks reporting.
Posted: Sat Jun 08, 2019 3:05 pm
by ConligWX
PS, are you using one of the recommended SD cards?
These are the currently supported microSD cards:
- swissbit SFSD1024N1BM1TO-I-DF-221-STD (microSD Card, 1 GB, SLC Flash, -40°C - 85°C)
- swissbit SFSD2048N1BM1MT-I-ME-221-STD (microSD Card, 2 GB, SLC Flash, -40°C - 85°C)
- swissbit SFSD2048N1BM1MT-E-ME-221-STD (microSD Card, 2 GB, SLC Flash, -25°C - 85°C)
- ATP AF2GUDI (microSD Card, 2 GB, SLC Flash, -40°C – 80°C)
- Cactus KS2GRIT-803M (microSD Card, 2 GB, SLC Flash, -45°C – 90°C)
- Panasonic SMSC02DA1 (microSD Card, 2 GB, SLC Flash, -40°C - 85°C)
- Apacer MSD02GIDI-T (microSD Card, 2 GB, SLC Flash)
Posted: Sun Jun 09, 2019 1:17 pm
When the LED goes to steady on, you should be fine. Did you test if it might just not take the IP you gave but operates fine on one given via DHCP from your router? You can test this with an IP scanner in your WLAN or by accessing the NANO SD via the remote link (this needs you to enable the remote feature on system tab first).
Posted: Sun Jun 09, 2019 5:06 pm
by Ag2000CO
The routers I am familiar with give a list of the assigned DHCP IP's.
Posted: Tue Jul 02, 2019 11:39 pm
by tofe
Sorry for the very late answers.
I have completely re-initialized the NANO SD several times (reset, 5x flashing), unfortunately without success.
I assign the IP addresses statically and have tried it with different free IP addresses. Again and again, the NANO SD is not available, the IP scanner used runs through again and again the whole possible IP range. The NANO SD is online, sometimes offline. All other devices and all other meteobridge are always online.
The web interface is compared to the other meteobridges very, very slowly loaded (sometimes factor 10x), again and again during the operation, the wireless connection is interrupted.
The NANO SD is not overloaded, only two services are running per minute.
After many Testst and since I have other meteobridges in use, I believe in a malfunction in the WLAN module.
Posted: Wed Jul 03, 2019 1:47 pm
by mthiessen
I'm not sure if this helps, but when I setup a dedicated IP for my Nano I not only set it in MB but I also had to make the same dedicated IP number in my Apple Extreme base station using Airport Utility. Although I'm running on Mac, there maybe something similar in your router. I found I had to set it in both places.
Posted: Thu Jul 04, 2019 4:16 pm
by tofe
Thanks for the hint. The router automatically registers the IP address. With all other meteobridge this problem does not exist, not even with the other NANO SD. The NANO SD gets access to the internal and external network, but the WLAN signal breaks off again and again, currently there is no access to the meteobridge.
Posted: Thu Jul 04, 2019 11:11 pm
by ConligWX
Just curious.
I take it you have one of the new NanoSD's - with the red wire? is it running with the same Davis power supply or a more powerful PSU?
Posted: Thu Jul 04, 2019 11:54 pm
by tofe
I have a Meteobridge NANO SD (in an Envoy, red cable, with 1A power supply)
Posted: Fri Jul 05, 2019 8:43 am
by ConligWX
Thank for the clarification. I can only think of two senarios in your case. either there is a faulty wifi antenna on the Nano or signal strength/compatibility issues on your wifi network.
have you tried the "Power Boost" option on the red Nano SD?
viewtopic.php?f=56&t=13795&p=28714
What type of wifi setup do you have? 802.11 ac /b /g /n ? any options withing you wifi access point you can change?
Posted: Fri Jul 05, 2019 10:10 pm
by tofe
Thanks for the two scenarios.
I have:
1x Meteobridge PRO
1x Meteobridge NANO (in a console)
1x Meteobridge NANO SD (in a console, black cable).
1x Meteobridge NANO SD (in a envoy, red cable, which causes problems).
All run smoothly with the same wireless settings, so I have in the latest NANO SD the same settings (auto, 2.4 GHz) without "Power Boost".
The NANO SD is sometimes recognized by the "Wireless Network Watcher" as online, sometimes offline. This is also true, when clicking on the NANO SD in any menu, the page is not found (offline).
Posted: Sun Jul 07, 2019 10:44 am
Try the power boost. your power supply seems fine to do so. If your WLAN issues are related to a weak WLAN connection this should help.
Please also try to operate the NANO in regular DHCP client mode and control fixed IP settings with your router based on the MAC of the NANO.
If that all does not help, I would propose a hardware change.
