Logging events that are unknown to me
FishH2o
Post by FishH2o »
Anyone know why this is happening and if its an issue or not? I dont really see any missing data on Weather Underground for my station.
wnetd (03.06.2019 02:19:28): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 02:19:33): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 02:20:47): message above repeats 15 times.
test5m (03.06.2019 08:20:56): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 02:20:56): process started.
wnetd (03.06.2019 02:43:08): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 02:43:10): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 02:45:36): message above repeats 30 times.
test5m (03.06.2019 08:45:41): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 02:45:41): process started.
wnetd (03.06.2019 02:46:06): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 02:46:12): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 02:50:36): message above repeats 56 times.
test5m (03.06.2019 08:50:39): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 02:50:39): process started.
wnetd (03.06.2019 04:13:39): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 04:13:40): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 04:16:40): message above repeats 38 times.
test5m (03.06.2019 10:16:40): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 04:16:40): process started.
wnetd (03.06.2019 04:17:02): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 04:17:05): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 04:20:10): message above repeats 32 times.
test5m (03.06.2019 10:20:12): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 04:20:12): process started.
wnetd (03.06.2019 04:21:07): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 04:21:11): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 04:25:38): message above repeats 53 times.
test5m (03.06.2019 10:25:42): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 04:25:42): process started.
wnetd (03.06.2019 04:26:04): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 04:26:11): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 04:31:39): message above repeats 71 times.
test5m (03.06.2019 10:31:39): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 04:31:39): process started.
wnetd (03.06.2019 05:31:44): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (03.06.2019 05:31:45): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.06.2019 05:36:11): message above repeats 53 times.
test5m (03.06.2019 11:36:16): weathernet daemon stalled, will be restarted now.
wnetd (03.06.2019 05:36:16): process started.
Re: Logging events that are unknown to me
The data upload process "wnet" runs into an internal error and terminates. It then gets started again and terminates again. This will need me to inspect the code on your system, as I cannot reproduce this error with my rig. Could you please send remote login credentials to "info(at)smartbedded.com"? Thanks!
