Weather34 on Nano SD **solved**
Ikoth
Post by Ikoth »
I've just installed my new Davis Vantage Pro 2 with Meteobridge SD Nano. Running ver 4.0 (Jun 15 2019, build 2160), FW 1.4
Everything is working well and I'm exporting data to a couple of web sites.
Now I want to get the fab looking Weather34 template working. I've read the README.md on GitHub, and it led me to the download link and seven step setup guide - https://weather34.com/homeweatherstation/
However, I'm stuck at step three - What are the FTP credentials to connect to the Meteobridge? I'm getting nowhere using the web GUI credentials.
I also found this, but its only an overview - https://weather34.com/homeweatherstatio ... ano34.html - Is there a detailed, NANO SD specific install guide anywhere?
Re: Weather34 on Nano SD
The Weather34 example shown down the bottom of your last link is included in the Weather Nets tab as Local Dashboard. Also see the release notes on November 21, 2018 under https://www.meteobridge.com/wiki/index.php/Forum
Ikoth
Post by Ikoth »
Perfect! Thank you.
mthiessen
Post by mthiessen »
I'm having the same problems with Weather34. How did you solve it?
mthiessen wrote: Mon Jun 17, 2019 4:13 pm I'm having the same problems with Weather34. How did you solve it?
What problems?
Do you want to install weather34 on your web server and use it there or do you want to use the weather34 install that comes with the NANO SD and use it locally on the NANO SD?
mthiessen
Post by mthiessen »
I want to use the MB install on the Nano.
mthiessen wrote: Thu Jun 20, 2019 11:27 pm I want to use the MB install on the Nano.
Then you have nothing to install. Just setup the network service "local dashboard" for that and you are done.
mthiessen
Post by mthiessen »
Thanks. My problem must have been a corrupt Weather34 install.
My problem was solved over here. viewtopic.php?f=56&t=14036
Cheers,
Mark
