Timezone database is corrupt **solved**
Ikoth
Post by Ikoth »
Hi all,
My newly installed system is showing this error:
2019-06-16 08:43:12 Error: 2019-06-16 08:43:11 <br /> <b>Fatal error</b>: date_create(): Timezone database is corrupt - this should *never* happen! in <b>/tmp/mnt/PWS/MB/mbdbfiles/nanocron.php</b> on line <b>6</b><br /> (no more tries)
Not sure what to do from here.
For context, I'd just added a "local dashboard" in an effort to use the Weather34 dash. When I click the "local display" button, a new tab opens for http://192.168.150.139/PWS/index.php but the page is blank.
Weather Underground, Darksky, CheckWX and Open Weathermap configs appear to be OK.
Re: Timezone database is corrupt
That's abnormal. What does your Nano config settings look like?
Did you install some templates yourself? When porting the weather34 templates for direct use on the NANO I also got this error and had to work around it. When you are using the weather34 variant that comes installed with NANO SD, you should be fine.
Ikoth
Post by Ikoth »
No, no custom templates. I did a clean setup on a brand new system, yesterday. Added a few weather service upload destinations, that appear to be OK.
This morning I setup the local dashboard option. Saw the page was blank, then noticed the timezone error on the Live Data tab.
Are there any logs or config files that will help correct the problem?
I think this will need me to have a look myself. Could you please allow remote login and send URL and password to "info(at)smartbedded.com"?
Ikoth
Post by Ikoth »
That's very good of you, thanks.
Can we arrange a rough time window for this please? I don't like leaving any elements on my network open for any remote access.
Cheers,
I.
Ikoth wrote: Mon Jun 17, 2019 6:40 pm That's very good of you, thanks.
Cheers,
I.
No elements are left open, simply change the password to something secure and different than you normally use and send it to Boris.
Ikoth
Post by Ikoth »
I sent the details on Sunday, thanks
Ikoth
Post by Ikoth »
Any update please...?
Ikoth
Post by Ikoth »
Hello...? HELLO...?????
As requested, I sent access details on Sunday, and I've not heard anything since.
Just found time to fix it on your system.
Ikoth
Post by Ikoth »
Much obliged! It looks fantastic :-)
Thank you very much.
