Stuck at version 3.8?
General information and solutions to the most prominent issues
Version "3.8" have a bug on some platforms that does not allow to skip to "newest" version when Meteobridge has once been manually forced to use "3.8". The symptom is that you select "newest version on boot" on "System" tab and when doing a reboot it will again show up in version "3.8".
The trick is to go down to version "3.6" or "3.7" first and when having booted with this older version then to select newest and reboot again. By doing so you escape the dead-lock.
