[BUG] Meteobridge Nano SD Weather Station Tab Error!
ConligWX
Post by ConligWX »
Has anyone else noticed the Rain field is offset in the Weather Station tab of the Nano SD?
Re: Meteobridhe Nano SD Weather Station Tab.
That value is a Multiplier, not an Offset
ConligWX
Re: Meteobridge Nano SD Weather Station Tab Error!
Post by ConligWX »
Mattk wrote: Sun Jun 23, 2019 2:00 am That value is a Multiplier, not an Offset
the "offset" is the "position" of the Rain field within the webpage.
ie it is offset to the wrong side.
look at the "Rain Multiplier" "Wind" and then look at the fields. they are not on the same lines. Doesnt matter what browser I use, it is messed up.
Copy that, see your meaning now but no I don't see that at all for either Nano or MBPro. First image below is a Nano, second is MBPro. Yes both appear identical but the are 2 separate units
Ag2000CO
Post by Ag2000CO »
Doesn't matter what browser I use, it is messed up.
I can reproduce your screen shot using my MB PRO and FireFox.
It is also correctable using <ctrl> 0 or <ctrl> + to resize the display (that is control "zero").
Press the control key <ctrl> and the "+" key several times to enlarge the display or <ctrl> - to shrink the screen.
Pressing <ctrl> 0 will return the screen to "normal" size.
Lou
Re: [BUG] Meteobridge Nano SD Weather Station Tab Error!
will be improved with next update.
