After USB Router Setup ... No Login into MB
Kiterider-markus
Post by Kiterider-markus »
Hello, i got the Meteobridge pro, and i Setup everything, i Used the Huawai E303 to see Data! But After i change the Network settings I try to connect with with the MB and the Network connects but if I type the IP address in the the Browser it shows me a Black screen where I have the Tap to start manually! My actually problem is that i can't get into the Panel Site of the Meteobridge after I set up the USB Router!
Hope you can help me out
REGARDS
Re: After USB Router Setup ... No Login into MB
Looks like you choose network settings that don't work.
www.meteobridge.com explains in "getting started" how to reset the MB PRO to network default settings to start over again.
