Nano SD needs reboot after router reboot
I have this problem that if I reboot my router the nano sd will stop sending to weather underground. I then need to reboot the nano sd. I can get to the nano sd and its up and running it just stop sending data. The nano sd is up to date on software.
Re: Nano SD needs reboot after router reboot
Connectivity work both way. The Nano, no doubt, is trying to send the data but your router has lost the connection to the Nano.
When you reboot your Nano, It sends the protocols to establish an internet connection, to the router. When you reboot the router it should try to establish connection with any thing/ every thing it can "see"
What type of router do you have?
Lou
I have a asus rt-ac68u. I have it running on one of the guest networks. Its the only wireless device that has this issue. The router is up to date on software.
