Exports are saved with wrong date?
Posted: Fri Aug 16, 2019 11:21 am
Hello all!
Got the Meteobridge NanoSD some month ago and it is up and running well.
Apart from my monthly and daily reports that are generated every night. I save them to my server with a datecode such as:
Montlyreport_[YYYY]-[MM].txt <-- The monthly report, resolution per day
Dailyreport_[YYYY]-[MM]-[DD].csv <-- Daily report, resolution per minute
One entry on the system tab generates the export, and one that is triggered by that event uploads with ftp.
If I run this using the "test" button it works out fine. But when run triggered the last datecode - month for the monthlyreport and day for the dailyreport is set to 01, so I get no daily reports saved since it is overwriting itself. The montly overwrites january every night.
Again, if run with the test-button it works as it I guess it is suppose to.
I did try to remove all entrys, reboot and add them again but without success.
Running Meteobridge 4.0 (Aug 11 2019, build 2251), FW 1.4
Attach screendump for the dailyreport settings and the outcome.
Any ideas what this might be??
