I then tried to craft a better mySQL upload query that would upload NULL if there was no data for PM2.5....which in the Meteobridge is variable air0pm.
Failed attempt at code:
INSERT INTO `mystation` (`ID`, `DateTime`, `TempOutCur`, `HumOutCur`, `PressCur`, `DewCur`, `HeatIdxCur`, `WindChillCur`, `TempInCur`, `HumInCur`, `WindSpeedCur`, `WindAvgSpeedCur`, `WindDirCur`, `WindDirCurEng`, `WindGust10`, `WindDirAvg10`, `WindDirAvg10Eng`, `RainRateCur`, `RainDay`, `RainYest`, `RainMonth`, `RainYear`, `UV`, `Solar`, `PM2.5`) VALUES (NULL, '[YYYY]-[MM]-[DD] [hh]:[mm]:[ss]', '[th0temp-act=F]', '[th0hum-act]', '[thb0seapress-act=inHg.2]', '[th0dew-act=F]', '[th0heatindex-act=F]', '[wind0chill-act=F]', '[thb0temp-act=F]', '[thb0hum-act]', '[wind0wind-act=mph]', '[wind0avgwind-act=mph]', '[wind0dir-act]', '[wind0dir-act=endir]', '[wind0wind-max10=mph]', '[wind0dir-avg10]', '[wind0dir-avg10=endir]', '[rain0rate-act=in.2]', '[rain0total-daysum=in.2]', '[rain0total-ydaysum=in.2]', '[rain0total-monthsum=in.2]', '[rain0total-yearsum=in.2]', '[uv0index-act]', '[sol0rad-act]', '#if#{*[air0pm-age:999]<300*}#then#[air0pm-max5=.0]#else#--#fi#')
Using that if the PM2.5 is not operational I get the following error still with no mySQL data upload:
2019-09-17 12:00:09 Error: 2019-09-17 12:00:02 MYSQL query 'INSERT INTO `mystation` (`ID`, `DateTime`, `TempOutCur`, `HumOutCur`, `PressCur`, `DewCur`, `HeatIdxCur`, `WindChillCur`, `TempInCur`, `HumInCur`, `WindSpeedCur`, `WindAvgSpeedCur`, `WindDirCur`, `WindDirCurEng`, `WindGust10`, `WindDirAvg10`, `WindDirAvg10Eng`, `RainRateCur`, `RainDay`, `RainYest`, `RainMonth`, `RainYear`, `UV`, `Solar`, `PM2.5`) VALUES (NULL, '2019-09-17 12:00:02', '90.3', '56.0', '29.97', '72.5', '98.2', '90.3', '77.7', '51.0', '2.2', '1.8', '302.0', 'WNW', '4.5', '276.0', 'W', '0.00', '0.00', '0.00', '3.78', '4.27', '7.0', '782.0', '--')' failed: Incorrect integer value: '--' for column 'PM2.5' at row 1 (no more tries):
Notice it says failed for value '--'
I've also tried to type in the word NULL instead of -- and it still doesn't work.
I'm thinking I need to do the IF THEN ELSE in mySQL instead. But I need help with the syntax. Another thought is to use IFNULL but again I need help with the syntax. Another idea is to use CASE IF THEN ELSE. I just have no idea yet how to implement the correct syntax.
Bottom line: I want to have a mySQL upload query that works even if [air0pm-max5=.0] is not providing any data. I think I'm on the right track but I need a little help.
