This is the result after flash MR3020 v1.8
mariomarconi
Post by mariomarconi »
I flashed the MR3020 v1.8 from original firmware (TP-LINK) to meteobridge ver. 1.5 and I got the result of a figure read from serial port (Putty). Can you fix it? The lan not work. I try change bitrate on putty but not change.
Re: This is the result after flash MR3020 v1.8
The MR3020 does not have an externally accessible serial port. If you soldered one to it on your own, you should be able to get the baudrate settings right to 115200 8N1. Apart from that the wiki explains how to access the meteobridge from your LAN. :roll:
mariomarconi
In fact, after flashing the hardware version 1.8 I no longer got access to the MR 3020 (lan), so I opened it and connected the serial following the instructions. The result is in the previous post.
From the garbled message I can identify something like busybox, which is a clear indication that the unit has started fine. Which of the following methods did you use to find out the IP?
- magicip.meteobridge.com
- led blinking
- router log
- ip scanner
mariomarconi
I used Advanced ip Scanner
