Access point operation disabled **solved**
katlon1234
Post by katlon1234 »
I keep getting these and after several hours everything stops updating and services.
system (11.10.2019 20:05:21): Access point operation disabled 999 secs after boot.
system (11.10.2019 20:21:25): Access point operation disabled 1963 secs after boot.
system (12.10.2019 21:50:42): Access point operation disabled 93720 secs after boot.
Re: Access point operation disabled
I guess you have a NANO. When unit is started it provides its own wifi network as you made use of when setting up the NANO. When the NANO has successfully connected to your WLAN, it shuts down its own WIFI network after 10 minutes or so. This is what the message is about. When Connection to your WLAN drops or gets instable, the WIFI gets switched on again to allow you to connect to it though connection to your WLAN might be not operational. When things are fine again WIFI is shut down again and another message is posted.
Looks like your WLAN is not stable resp too weak from where the NANO is located.
katlon1234
Thanks for the info. Makes sense now. I will move the wireless access point closer to the console for a better signal and see if that helps. Thanks.
Lonnie
