Funny messages in log... **solved**
webcam
Post by webcam »
since the last update I always get these messages.
Are these normal?
logger (08.11.2019 07:00:25): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 07:00:45): message above repeats 5 times.
database (08.11.2019 07:00:46): database sync done (39 tables, 144/1677 writes).
logger (08.11.2019 07:00:49): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 07:57:14): message above repeats 841 times.
logger (08.11.2019 07:57:14): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 07:57:14): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 07:57:14): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 07:57:18): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 07:57:18): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 07:57:18): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 07:57:18): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 07:57:22): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 07:57:22): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 07:57:22): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 07:57:22): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 07:57:26): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 08:05:26): message above repeats 115 times.
logger (08.11.2019 08:05:26): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 08:05:26): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 08:05:26): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 08:05:30): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 08:05:30): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 08:05:30): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 08:05:30): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 08:05:34): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 08:05:34): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 08:05:34): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 08:05:34): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 08:05:38): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 09:56:37): message above repeats 1659 times.
logger (08.11.2019 09:56:37): unknown data format while reading from device 7/1 channel 300: 0x03
logger (08.11.2019 09:56:37): unknown data format while reading from device 7/1 channel 305: 0x03
logger (08.11.2019 09:56:37): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 09:56:37): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 09:56:37): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 09:56:41): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 09:56:41): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 09:56:41): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 09:56:41): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 09:56:45): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 09:56:45): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 09:56:45): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 09:56:45): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 09:56:49): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 13:00:29): message above repeats 2749 times.
logger (08.11.2019 13:00:29): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 13:00:29): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 13:00:29): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 13:00:34): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 13:00:34): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 13:00:34): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 13:00:34): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 13:00:38): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 13:00:38): unknown data format while reading from device 7/1 channel 460: 0x03
logger (08.11.2019 13:00:38): unknown data format while reading from device 7/1 channel 400: 0x08
logger (08.11.2019 13:00:38): unknown data format while reading from device 7/1 channel 500: 0x05
logger (08.11.2019 13:00:42): unknown data format while reading from device 7/1 channel 101: 0x08
logger (08.11.2019 18:54:15): message above repeats 5301 times
Re: Funny messages in log...
What Lufft model?
webcam
Post by webcam »
I have the WS700 UMB..
This would be something for Boris. Have you tried going back to the previous version that worked which will confirm the latest version?
webcam
Post by webcam »
Ok, install the old version again.
Then I look again.
Merci ......
webcam
Post by webcam »
At 4.1 these messages do not come .....
oled (11.11.2019 05:32:43): process started.
database (11.11.2019 06:34:43): process started.
database (11.11.2019 06:34:43): Content of RAM database restored.
wnetd (11.11.2019 06:34:45): process started.
system (11.11.2019 06:34:45): start of logging process initiated.
logger (11.11.2019 06:34:46): databases connected. Update interval 3600 seconds.
logger (11.11.2019 06:34:46): data logger (version 5.1b, build 13193) started.
logger (11.11.2019 06:34:47): connect station 0 (WS600/700/10 via USB serial).
logger (11.11.2019 06:34:47): connect station 9 (System Data via Plug-in).
logger (11.11.2019 06:34:47): compact weather station device 7-1 activated: WSx-UMB
logger (11.11.2019 06:34:47): compact weather station device 7-1 identifies as: No. 204, Project 1305, HW 0.8, SW 0.12, device 223
logger (11.11.2019 06:34:47): compact weather station device 7-1 provides 13 channels: 100, 101, 110, 200, 300, 305, 460, 400, 401, 500, 700, 600, 800, 900
logger (11.11.2019 06:34:50): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (11.11.2019 06:34:50): services paused.
logger (11.11.2019 06:34:51): sensors are now providing data.
logger (11.11.2019 06:34:51): services started.
database (11.11.2019 06:35:13): database sync done (39 tables, 117/1677 writes).
I have to make some changes for the WS-10 model. Looks like these changes don't go well with the 700.
Can you please give me a remote login? As I don't have a 700 myself I cannot debug otherwise.
webcam
Post by webcam »
Link I sent with PM.
Thanks for your help.
thanks, will take care the next days... this WE is rather busy with private stuff.
The just released update should fix this. Handling of empty messages from the WS-700 had some short-comings, which should be solved by now.
webcam
Re: Funny messages in log... **solved**
Post by webcam »
Thanks.....
Greeting
Daniel
