Nano SD Local Dashboard Problem ** Partially solved**
augiedoggie49
Post by augiedoggie49 »
Just got Nano SD and Local Dashboard was working after initial setup. Reset to default settings to start over with fresh database (5 flashes) Then setup internet connection, etc and imported the config I saved earlier. Everything else works, but now clicking the Local Dash button leads to the following message and no dashboard:
The requested URL /PWS/index.php was not found on this server.
Tried the reset dashboard button twice, but it didn't help. Any suggestions greatly appreciated.
Update!
Update: Found a post in meteobridge pro that worked:
'You can fix that by calling: "http://ip-of-your-meteobridge/cgi-bin/system.cgi?rm /tmp/mnt/PWS/version"
This removes the version marker so that Meteobridge does think on next reboot, that dashboard needs to be installed. Please be patient on reboot, Meteobridge will be in LED pulse mode for a while (while downloading and installing dashboard) before the LED turns steady on.'
Update:
After initially thinking that the problem was completely solved, it returned. Couldn't be found on this server again message as noted above. Reset button didn't work second time, but used the http request and a fresh installation of the dash meant I had to set all of my admin preferences for the dash page again. I just don't want to have to keep configuring the page settings if the weather34 dash gets corrupted regularly. Will see over the next few weeks if it remains stable and post again.
