Crash and restart - weathernet daemon stalled
tjones
Post by tjones »
Getting this occasionally on my WL-330N3G unit that has been running for years. Need some help on the cause.
logger (08.11.2019 10:06:13): services started.
wnetd (14.11.2019 06:22:34): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (14.11.2019 06:22:42): open named pipe "/dev/meteobridge" failed: No such device or address
logger (14.11.2019 06:25:56): message above repeats 25 times.
test5m (14.11.2019 11:25:56): weathernet daemon stalled, will be restarted now.
wnetd (14.11.2019 06:25:56): process started.
wnetd (14.11.2019 06:47:48): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (14.11.2019 06:47:52): open named pipe "/dev/meteobridge" failed: No such device or address
logger (14.11.2019 06:50:18): message above repeats 20 times.
test5m (14.11.2019 11:50:19): weathernet daemon stalled, will be restarted now.
wnetd (14.11.2019 06:50:19): process started.
wnetd (15.11.2019 14:53:21): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (15.11.2019 14:53:26): open named pipe "/dev/meteobridge" failed: No such device or address
logger (15.11.2019 14:55:22): message above repeats 16 times.
test5m (15.11.2019 19:55:24): weathernet daemon stalled, will be restarted now.
wnetd (15.11.2019 14:55:24): process started.
wnetd (15.11.2019 15:05:57): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
test5m (15.11.2019 20:05:58): weathernet daemon stalled, will be restarted now.
wnetd (15.11.2019 15:05:58): process started.
wnetd (15.11.2019 15:11:02): process received signal (11) and terminated: wnet_handle* < appendlog < wnet_handle < send_data* < debugmsg* < debugmsg < send_wnet* < flat
logger (15.11.2019 15:11:08): open named pipe "/dev/meteobridge" failed: No such device or address
logger (15.11.2019 15:16:04): message above repeats 42 times.
test5m (15.11.2019 20:16:11): weathernet daemon stalled, will be restarted now.
wnetd (15.11.2019 15:16:11): process started.
Re: Crash and restart - weathernet daemon stalled
logging process seems to crash. it is restarted but these crashes should not occur. Could you please give me remote access so that I can check out a few things? Please mail to "info(at)meteobridge.com".
tjones
Post by tjones »
Email sent.
