Nano SD Local Dashboard Fatal Error Sun **solved**
Posted: Sat Nov 23, 2019 6:09 pm
by augiedoggie49
I have the 'Fatal Error uncaught exception' for the sun position in the Weather34 dashboard. My timezone selection in the system tab is 'Los_Angeles.' I think the '_' is causing the problem. I tried changing the timezone to one that is one word and rebooted, but the Weather43 page still sees the old Los Angeles timezone. Can anyone help?
Re: Nano SD Local Dashboard Fatal Error Sun
Posted: Sun Nov 24, 2019 12:07 am
by weatherist34
should be America/Los_Angeles
reference here
https://www.php.net/manual/en/timezones.america.php
make sure no spaces before or after .
Posted: Sun Nov 24, 2019 9:25 pm
by augiedoggie49
I understand that the space would be a problem. The problem is that the Sun Position panel in Weather34 local dash shows the Fatal Error: Uncaught exception because of a problem when I select America/Los_Angeles in the System tab of meteobridge Nano SD. I don't know how to fix or edit or whatever is needed.
Posted: Sun Nov 24, 2019 10:53 pm
by weatherist34
augiedoggie49 wrote: Sun Nov 24, 2019 9:25 pm
don't need to edit system or change anything system tab use the setup menu in dashboard itself example below
- Screenshot at Nov 24 23-51-33.png (19.74 KiB) Viewed 2456 times
Posted: Mon Dec 09, 2019 5:40 pm
by augiedoggie49
I did use the system tab and selected America/Los_Angeles as in your screenshot. It didn't fix the problem, so I selected America/Tijuana because that location is still in my timezone, and this selection does not include an '_' . This worked for me. I believe I read a post where someone else had this problem but they did some editing to fix it. Sorry I don't know where that post is now.
