My device has recently begun stalling out on regular data uploads to WU, CWOP, etc. The device is otherwise responsive and will briefly resume uploads upon reboot. Newest updates are applied at each reboot, and device appears to be connected to LAN and WAN (although at one point I observed that the WAN fields on the system page were not populated - but after switching tabs the WAN IP and provider later appeared). Most recently reboot worked for under 24 hours. Last message in log related to execution of daily backup. Can anyone suggest how I might approach debugging this elusive problem?
snip of current log that includes some manual exports I did yesterday that were unrelated to this issue. The last successful update to one service was at the time the services were activated in the log below at 13:38.
logger (26.11.2019 13:36:59): listening to transmitter 2
logger (26.11.2019 13:36:59): bandwidth normal
logger (26.11.2019 13:36:59): chip authentication ok: 14
logger (26.11.2019 13:36:59): frequency band 915MHz (US)
logger (26.11.2019 13:37:00): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (26.11.2019 13:37:00): services paused.
database (26.11.2019 13:37:10): database sync done (46 tables, 0/1932 writes).
logger (26.11.2019 13:38:57): give up waiting for sensors after 120 secs.
logger (26.11.2019 13:38:57): services activated.
export (27.11.2019 08:05:32): 1440 lines of data written to file: standard-imp-20191126-min.txt
export (27.11.2019 08:13:42): 1440 lines of data written to file: revisedstandard-imp-20191126-min.txt
export (27.11.2019 08:16:45): 1440 lines of data written to file: revisedstandard-imp-20191126-min.txt
export (27.11.2019 08:17:43): 1440 lines of data written to file: revisedstandard-imp-20191126-min.txt
backup (27.11.2019 13:38:58): backup media size is 2.0G (810.8M free).
Pro stops uploading data to services?
zmcreynolds4
- Fresh Boarder
Re: Pro stops uploading data to services?
I am observing the same problem : data uploads, as well as any display configured, are not working after a scheduled backup (using the backup.sh script). Even a reboot triggered by pressing the "reboot" button of the web interface is not working : the message "reboot" is displayed, but nothing happens.
I have to switch off /on the device and then everything is good until the next scheduled backup.
My Meteobridge pro is running v4.2 (Nov 23 2019, build 13283).
EDIT : I just tried to launch the backup manually (from the System tab) and the same problems occurred just after the manual backup. I will try to use a new USB key.
zmcreynolds4
- Fresh Boarder
I had also taken obvious step of disabling my backup prior to the last reboot since that was the last thing that happened prior to the problem. Makes sense to investigate the USB destination for a problem which I can do. Thank you.
On my side, it was definitively a problem with my external USB key. Apparently, the backups of the last few days were started, but never finished as suggested by the size of the backup files that was lower than expected.
No problems with the new USB key
