Hi Everyone!
Here's my situation. I have had meteobridge for a few years now. It was running on an Acurite weather station using the SmartHub. But, since they phased it out, obviously it doesn't work.
What weather station would you recommend in the $150-250 range?
Also, I've read that meteobridge will NOT work with Acurites new Access unit?
What would you recommend. Looking to purchase today if possible! Thanks!
Bryan
Need help deciding what weather station to purchase
- Fresh Boarder
Re: Need help deciding what weather station to purchase
Get something from Ecowitt. If you get one of the various GW100x models it will work with Meteobridge. If you want something with a display like the HP2551 station then you can add the GW1000 gateway device for the sake of the Meteobridge. Or the other way around for example GW1002 station and then add the HP2551-C display.
http://www.ecowitt.com/weather_station/
Meteobridge RPI | GW1000
