Rain total month/yearsum calculation **solved**
thunderstorm
Post by thunderstorm »
Hi Boris,
when does meteobridge calculate rain-total sums for month & year ?
I noticed today that my yearsum and monthsum is less than the daily one.
Screenshot 2020-01-04 at 10.48.36.png (23.22 KiB) Viewed 2908 times
Is is maybe end of hour ? In that specific hour I had 0.5mm precipitation, and there have been 0.3mm in the days before and after the next full hour the yearsum was 3.8mmm.
Same is true when I export [rain0total-daysum.1:] & [rain0total-yearsum.1:]
Could it be calculated so that it also outputs the amount since the last aggregation ?
Best,
Bernd
Re: Rain total month/yearsum calculation
There have been some changes in that area. Please check if just released code does solve this.
thunderstorm
OK, I'll check once it starts raining again
thunderstorm
Hmm, it seems to be fixed to some extent - but I sometimes see wrong values at full-hour exports ? Is that a concurrency issue ?
07/01/20,09:55,3.2,89,1.6,3.0,8.9,255,4.2,1.0,1031.8,4.8,,,,,,,17,,
07/01/20,10:00,3.0,89,1.4,1.2,6.9,230,2.1,1.0,1031.8,3.8,,,,,,,27,,
07/01/20,10:05,2.9,90,1.4,2.6,8.9,221,1.2,1.0,1031.8,4.8,,,,,,,47,,
07/01/20,14:55,4.0,94,3.1,0.4,2.0,235,0.0,1.3,1032.8,5.1,,,,,,,25,,
07/01/20,15:00,4.0,94,3.1,0.1,0.9,234,0.0,1.3,1032.9,4.8,,,,,,,24,,
07/01/20,15:05,4.0,94,3.1,0.3,2.0,234,0.0,1.5,1032.9,5.3,,,,,,,24,,
07/01/20,15:55,3.9,94,3.0,0.0,1.0,234,0.0,1.5,1033.1,5.3,,,,,,,18,,
07/01/20,16:00,3.9,94,3.0,0.1,0.9,234,0.0,1.5,1033.2,5.1,,,,,,,18,,
07/01/20,16:05,3.9,94,3.0,0.0,0.0,234,0.0,1.5,1033.2,5.3,,,,,,,14,,
Bernd
Can you please share the template you are using?
thunderstorm
Same as here
#if#{*[th0hum-avg5.0:]>0*}#then#[DD]/[MM]/[YY],[hh]:[mm],[th0temp-avg5.1:],[th0hum-avg5.0:],[th0dew-avg5.1:],[wind0wind-avg5=mph.1:],[wind0wind-max5=mph.1:],[wind0dir-avg5.0:],[rain0rate-avg5.1:],[rain0total-daysum.1:],[thb0seapress-avg5.1:],[rain0total-yearsum.1:],,,,,,,[sol0rad-avg5.0:],,#else##no data - [YY][MM][DD][hh][mm] #fi#
This should be solved with todays update.
