Only a blinking led after flash
Alex202
Post by Alex202 »
Just did a Flash of Meteobridge Firmware to TL-MR3020
All went well until after the TP-Link screen read "rebooting device etc.".
The TL-MR3020 started blinking with the largest led (wps) slowly until after a few minutes it was suddenly blinking very fast.
As I understand the documentation it is trying to load the meteobridge stack.
Nothing happens, only blinking.
The TL-MR3020 is connected to the LAN directly, no address in the network is seen for this device.
Emergency ip address of 192.168.1.111 (version 1.1) is not found when scanning.
The only "non-normal" aspect of my setup is that there is another meteobridge (Asus) on the network which is fully operational.
Thanks for looking into it.
c.today/
Re: Only a blinking led after flash
There is no emergency address! Who gave you this wrong and completely misleading information?
When it is stuck at fast blinking the LAN/WLAN credentials you were giving do not work.
You can reset to default network operation as explained in "getting started" section of www.meteobridge.com.
