Hello all,
After returning from out of town, I noticed there have been a few updates since the January 8th release. I rebooted the Nano SD to grab the latest build. After a few minutes, I received the standard system message that the Nano was not fully started yet and waited for several minutes. Performed a continuous ping and was getting 100ms+ replies and several minutes of no replies. Ping would return again with high ping times followed by no replies. Went to web UI and got the not started yet message.This went on for over an hour. Reset network config by depressing button but still hung onto previously defined static IP. Performed again twice. Next reset creds, with same behavior. Performed my last ditch effort and factory reset by waiting for 5 blinks. Pinged 192.168.169.1 and times are 1-2 ms now, but still getting Warning: Meteobridge not started yet in web UI.
I can get to Web UI, SSH to device and ping, but no luck getting to license screen or network config page. Basically I'm stuck. Device has worked flawlessly until latest restart and build.
Any advice for next steps?
Thanks all
Nano SD wont Boot. Bricked?
Re: Nano SD wont Boot. Bricked?
Update:
Performed factory reset on device again, and was able to access the web UI to begin config. Restored 2 week old configuration and seems to be running again. Ping times have dropped from 100ms to 30ms from local computer to Nano. Still unusually high for local ping and several drops.
