[BUG?] Errors in Davis transmitters config?
Clément
Post by Clément »
I wonder if there isn't a bug in the Davis transmittters config menu.
I would like to set Transmitter #1 as ISS with Reapeater A.
When this config is set in the Weather Station tab, I see in logs (System tab).
"Transmistter #1 as ISS with Repeater H".
Is it only a display bug or it tries to configure with repeater H instead of A?
Re: [BUG?] Errors in Davis transmitters config?
What kind of Meteobridge device are you using?
Clément
Post by Clément »
TL-MR3020
FW1.4, 4.3 build 13355 2020-01-30
in combination with a Davis USB logger?
I checked the code. It is just a display issue, which will be fixed in the next update.
