502 Bad Gateway errors. **solved**
Posted: Sat Feb 01, 2020 10:49 am
by gcams
Getting frequent 502 Bad gateway errors from the Meteoplug web server just now which is making a bit of a mess of my website with the embedded iframes. Can you look into this please??
Re: 502 Bad Gateway errors
Posted: Sat Feb 01, 2020 4:51 pm
by grwkak
Its been happening since the transition to the new server. On and off - I don't see a pattern.
See it right now on my Meteobridge (Meteoplug Cloud (live)):
http://logger.meteoplug.com/cgi-bin/live.pl: 2020-02-01 09:52:09 ERROR 502: Bad Gateway. (no more tries)
Guy
Posted: Sat Feb 01, 2020 5:21 pm
by gcams
grwkak wrote: Sat Feb 01, 2020 4:51 pm
Yes I agree this started with the server change and occasionally occurs but it's been particularly bad in the last 24 hours or so.
I originally posted about it here and got no response:
viewtopic.php?f=63&t=14533&start=15#p31393
But right now it's so bad my website visitors are complaining.
Posted: Sat Feb 01, 2020 7:37 pm
by frabey
Hallo Boris,
Was ist mit dem Server los? Immer wieder der 502er Fehler seit dem Serverwechsel.
Seit du Meteoplug veröffentlicht hast gab es nie solche starken Probleme.Erst in letzter Zeit zeigt Serverstatus ist auch sehr häufigen Serverausfall bzw. fehlen die Auslastungsdaten daten.
Wäre super wenn das System wieder vernünftig laufen würde.
Posted: Sun Feb 02, 2020 3:56 pm
by gcams
The 502 errors still continue frequently today as well. It would be great to get an update on this issue.
- Screen Shot 2020-02-02 at 13.53.45.png (14.8 KiB) Viewed 14321 times
Posted: Sun Feb 02, 2020 4:29 pm
by grwkak
I posted in the Meteobridge forum on this topic. Hoping someone can look at this. It also affects my iframes on my website.
Guy
Posted: Sun Feb 02, 2020 6:50 pm
by Rutishauser
frabey wrote: Sat Feb 01, 2020 7:37 pm
Hallo Boris,
Hallo zusammen
Ich schliesse mich dem an: Seit dem Serverwechsel kommen diese Fehler teilweise häufig.
Zudem ist das bearbeiten der Grafikdefintionen zum Teil unmöglich geworden...
Posted: Mon Feb 03, 2020 12:30 am
Please read the other posting about live data services. Operation should be now fine again.
Posted: Mon Feb 03, 2020 4:06 pm
by Stormedy
Dear Boris, I contacted Kai Kobler (Kaiko) yesterday about the Bad Gateway errors. It is now functioning but on my weather page the Meteoplug live graphic is not functioning! I think also with Kaikos Weather page!
Can you check my website:
http://www.kaikowetter.ch/mc/meteoplug_seegrabenX.html
on the live graphic including the wind compass does not show any data!
Thanks for your info - hope this will be in order soon!
regards
Edward
