I upgraded to v2.6 and now I can't connect to the files on Meteohub through SMB.
Meteohub won't let me go back to an older version either... I'm stuck without access!
Very upset since I thought we were beyond these kinds of issues.
Can't connect to SMB server after v2.6 upgrade **solved**
Re:Can't connect to SMB server after v2.6 upgrade
2.6 has not changed anything to smb. Taking your other posts of recent problems together this looks very much like a corrupted filesystem caused by a bad stick. Do I have a chance to login your Meteohub from the outside? please pm to info(at)meteohub.de.
I formatted and started over. I can get in now.
Re:Can't connect to SMB server after v2.6 upgrade **solved**
I thought I had the same problem, but I realized that when the web console password is changed, the SMB password does not change and stays as "meteohub/meteohub."
