api.ipify.org **solved**
alexrodriguez
Post by alexrodriguez »
I noticed in my pi-hole is currently blocking api.ipify.org from Meteobridge. Is access to api.ipify.org required for Meteobridge to operate correctly?
Re: api.ipify.org
It is used to get the WAN IP of your Meteobridge. Not mandatory needed, but then WAN IP field on System tab will remain unfilled.
Do you have a problem with outgoing traffic to there? When you inspect the paypload you will see that no information is sent out, it is just an IP request.
alexrodriguez
Re: api.ipify.org
admin wrote: Thu Feb 20, 2020 12:23 pm Do you have a problem with outgoing traffic to there? When you inspect the paypload you will see that no information is sent out, it is just an IP request.
No, I am fine with it. I just whitelisted it.
