WeatherFlow Live Sensor data issue
NEW2ARK
Post by NEW2ARK »
i have 2 AIR and 1 SKY modules...the Live data sensors show weird data Outdoor #1 and Indoor #1 are from an AIR and Outdoor and Indoor are from the 2nd AIR...I have tried to change the sensor names to no avail...I am thinking this is why my HEAT INDEX/WINDCHILL and FEELS LIKE data is not correct...
https://pwsincabotar.com/
Re: WeatherFlow Live Sensor data issue
you might need to make the outdoor air sensor the primary temperature sensor ..
Screenshot at Feb 23 01-07-33.png (49.29 KiB) Viewed 2431 times
NEW2ARK
Post by NEW2ARK »
It is a Primary sensor
perhaps delete the indoor sensor from the wf hub altogether until you can establish that the outdoor air is the primary sensor for temp etc .. once established then re add the second indoor sensor as a complete new device .im only basing it on previous use of multiple air sensors unfortunately i gave up with wf stuff so i cant confirm the windchill readings but i seem to recall various threads on wf forum .good luck in finding the resolve.. ps looking on your site its or was reporting windchill in the template .the feels like box auto switches to windchill when windchill value is reported
NEW2ARK
Post by NEW2ARK »
OK...thanks...I removed my indoor AIR and I now get the following:
this doesnt make sense to have an indoor and outdoor sensor with just an outdoor AIR???
hello good morning
as above i dont use wf anymore but all i can think is can you right click the indoor sensor in the live data screen and disable it ?
im just guessing could be totally wrong.. boris did respond to your other thread so he is basically saying th0 and wind sensor need to be aligned. probably by the time you resolve it the winter will be over , unfortunately there is not much help for wf stuff users i knew were using it have pretty much given up based on the other issues i.e rain,solar panel etc.. if had one connected i would try stuff before giving you answer but i dont..perhaps someone else can chime in
