Wired Davis Vantage Pro2 displays "phantom" sensors **solved**
SANdood
Post by SANdood »
Please Help!
I have reported this before, but it was manageable because I could simply hide the extraneous sensors. Apparently, there is a limit to the number of sensors that I can hide, because it won't let me hide them all.
Note that this is a WIRED Vantage Pro2, using the stock Ethernet connector from Davis. There should be no way that there are ANY extra sensors, but Meteobridge insists that there are 7.
Here's my Live View:
Historical View:
And finally, my System page:
Help, please!
Re: Wired Davis Vantage Pro2 displays "phantom" sensors
Did you configure the console accordingly? As I don't have a cabled Vantage, I cannot test this with my rig. Con you give me remote access to your Meteobridge and send credentials to "info(at)meteobridge.com"?
SANdood
Post by SANdood »
I haven't changed the console configuration, and the console itself reports that is only has ONE sensor (the ISS)...
Access being sent under separate cover...
SANdood
Post by SANdood »
I see that you were able to fix it - thank you very, very much!!!
fixed with just released version.
