Conversion
Ed_Heaton
Conversion
Post by Ed_Heaton »
I need help converting the Rain string to "in" from "mm". Also if you could help convert the Pressure to "inHg" instead of "hPa" .
Time: [hh]:[mm] • Temp: [th0temp-act=F.1:--]°F • Wind: [wind0dir-act=endir:---] [wind0wind-act=mph.1:--] to [wind0wind-max10=mph.1:--]mph • Pressure: [thb0press-act:--]hPa • Rain: [rain0total-sumday]mm • Hum: [th0hum-act.0=:--]% • ET: [sol0evo-act.1=:--]mm • Solar: [sol0rad-act:--]W/m² • UV Index: [uv0index-act:--] • Sunrise: [mbsystem-sunrise:--] • Sunset: [mbsystem-sunset:--] • Cloudbase: #if#[th0temp-act.1:0.0]>[th0dew-act.1:0.0]#then#{*([th0temp-act.1:0.0]-[th0dew-act.1:0.0])*400*0}#else#0#fi#ft •
Re: Conversion
Pressure: [thb0press-act:--]inHg
Rain: [rain0total-sumday]in
Please read the following http://www.meteobridge.com/wiki/index.php/Templates especially the Convertors section
