Meteobridge nano sd data import **solved**
Leon
Post by Leon »
Hi All,
I need some help/advice.
I am trying to import data to my meteobridge nano sd.
On my network I see the import folder and have successfully added the file I want to import but then on the meteobridge interface I cannot find the file...when I click on import files there are none ?
Please see attachments.
Regards and thank you,
Leon Rossouw.
Image 2.png (152.22 KiB) Viewed 2608 times
Image 3.png (137.3 KiB) Viewed 2608 times
Image 4.png (114.28 KiB) Viewed 2608 times
Leon
Re: Meteobridge nano sd data import
Post by Leon »
I have not solved this problem yet.....help please !!!! :shock: :roll:
can access the sd card on my network and import files but cannot in the meteobridge interface get it to show. ??
Regards,
Leon.
you need to start the import function on "history" tab. When the file does not show up in the "Select File" list, then something is wrong. Did you check file attributes? May be it is nor readable by all users?
Please post result of
http://ip_of_your_meteobridge/cgi-bin/system.cgi?ls -la /tmp/mnt/data/import
Leon
Post by Leon »
My problem is i can access the sd card on my local network via my pc or iPad....but when i open the nano sd interface and for example export a chart it says export completed but it is not there in the charts folder. Or data...Or there is a .csv file in the import folder which shows on local network but I cannot access it in the nano sd interface.
It shows in the log...see attachment.
Regards,
Leon.
Leon
Post by Leon »
Or I generate and export a chart..it says it was done successfully but there is nothing in the chats folder...see attachments please.
Regards,
Leon.
Image 2.png (46.36 KiB) Viewed 2557 times
Image 3.png (33.13 KiB) Viewed 2557 times
Leon
Post by Leon »
Problem solved ! :D :D :)
In the end I did a complete restore (reset button 5 flashes)
communication meteobridge sd card and network now 100%
Regards,
Leon.
