Wrong min.-/Max-Values submitted to WL-Cloud, problem is back
xray77
Post by xray77 »
The problem comes back again: wrong min/max values are transmitted to the WeatherLink network (Weather-Networks -> WL-Cloud).
Current version:
Meteobridge NANO SD (awekas version)
RAM: 125572 kB total, 44980 kB free (64% used)
Memory: swissbit SLC, 1825 MB total, 1777 MB free (3% used)SW-Version: Meteobridge 4.3 (Apr 7 2020, build 3041), FW 1.4
Runtime: 13 hrs, 28 minutes Puffer: 1 entry (0%)
Restarting the system did not help. test transmission of the values via PC and program WeatherLink then displays correct values in the WeatherLink network. The current values are not affected by the error, only the min/max values.
First Picture: the wrong Min.-/Max-Values on temperature, also other min.-/Max-Values are wrong
Second Picture: the correct Values submitted from WeatherLink to WL-Cloud via PC.
Is there any fix available or can I do something to fix it?
Thanks and best regards
Mike
Bildschirmfoto 2020-04-06 um 09.28.10.png (120.81 KiB) Viewed 4244 times
Bildschirmfoto 2020-04-06 um 09.38.17.png (116.64 KiB) Viewed 4244 times
