hello I am currently on version 5.0s (build180) I would like to know if I should update the meteohub system on this subject 2 questions
the first what is the procedure to follow?
the second following the update is there a risk of losing the data for the current year in terms of rainfall for example or a loss of other data (temperature pressure)? and therefore to start from zero after the update
currently everything is working perfectly is it really necessary to do it? thank you
update
