Reverting 3020v3 back to stock
staze
Post by staze »
Hi All,
Curious if anyone knows how to convert an MR-3020v3.2 back to stock. I've tried just http://<meteoip>/cgi-bin/fwupdate.cgi, and the tftp method. Neither seem to work. fwupdate says the firmware isn't a supported format. tftp just never grabs the file.
Would like to convert this guy back to being a little travel router since I have a MB Nano SD now. =)
staze
Re: Reverting 3020v3 back to stock
Post by staze »
Okay, got it! What a fun experience. lol
Grab the firmware from here: https://www.tp-link.com/in/support/down ... /#Firmware
Extract and rename to "tp_recovery.bin".
Remove the boot sector info using:
dd if=tp_recorvery.bin of=tp_recorvery_fixed.bin skip=257 bs=512
SCP the firmware to the device.
scp tp_recovery_fixed.bin root@10.0.0.2:/tmp/tp_recovery_fixed.bin
ssh into the device
ssh root@10.0.0.2
and run mtd
mtd -r write tp_recovery_fixed.bin firmware
Once it's rebooted and stayed a while, recommend powering off, holding "reset" and powering on. Hold reset for a good 20 seconds, then release.
Device should reboot, and come back up in router mode.
