I wonder whether RSTP protocol is supported. It seems to me it is not, is there a plan do support it?
Thank you
Camera integration: does meteobridge support RSTP. **solved**
Re: Camera integration: does meteobridge support RSTP
no, it is an embedded device that cannot handle that amount of data.
36260
- Expert Boarder
My Cam support RSTP substream that be set with various bit rates and image size. In those conditions could it support the amount of data which is reduced?
What brand and model camera do you have. Most of them support still shot. Seems to me like you are wanting to use RTSP because you don't know how to get a still shot.
Meteobridge RPI | GW1000
36260
- Expert Boarder
After a lot of search, I stumbled on iSpy and thanks to that I discovered that the correct instruction for a Dahua DH-IPC-HDBW2431RP-ZS cam is
http://user:pass@ip/cgi-bin/snapshot.cgi?1Re: Camera integration: does meteobridge support RSTP
Well I could have saved you the time and trouble if you had answered my question of what camera you have, as I was planning of providing you with that information. But even better than iSpy is the excellent documentation from Amcrest which is a lot nicer and more complete and works for all Dahua clones. For other brands there exist their documentation. ISpy is just convoluted and disorganized and duplicates information.
Amcrest documentation:
https://s3.amazonaws.com/amcrest-files/ ... 3.2017.pdf
36260
- Expert Boarder
Thanks a lot for the documentation, very valuable information.
- ConligWX
I've used wget in the past for grabbing a snapshot like so:
viewtopic.php?p=27037#p27037
or you could use ffmpeg for a rtsp stream.
then ftp the image.jpg to WU.
the camdata.txt is processed by mb to add the weather values (templates) you want as a layer on the image.
#!/bin/sh
#set variable yday to be like 20100208
#tday=$(date -d today +%Y%m%d%H%M%S);
#stamp=$(date '+DATE: %d/%m/%y%nTIME:%H:%M:%S');
tday=$(date +%Y%m%d%H%M%S);
#stamp=$(date +%Y%m%d);
# get weather image
ffmpeg -rtsp_transport tcp -i rtsp://ip.cam.with.port:xxx/xxxxxxxx -vf scale=1280:720 -frames 1 /share/htdocs/sky1.jpg -y;
# next 2 lines add weather info
testdata="$(/bin/cat /share/htdocs/camdata.txt)";
testdata1=`date +"%A %d-%b-%Y %R %Z"`;
# use Convert to add WX values and date etc to the image
/bin/convert -fill RoyalBlue4 -draw "fill-opacity 0.4 rectangle 0 0 1280 25" \
-fill red -draw "fill-opacity 0.6 rectangle 0 26 1280 27" \
-fill RoyalBlue4 -draw "fill-opacity 0.7 rectangle 0 695 1280 720" \
-fill red -draw "fill-opacity 0.6 rectangle 0 693 1280 694" \
-fill white -pointsize 18 -font /share/db_backup/script/arialbold.ttf -draw "text 10,20 'Conlig Weather Station: $testdata1 • www.conligwx.org'" \
-fill yellow -pointsize 18 -draw "text 10,715 '$testdata'" /share/htdocs/sky1.jpg /share/htdocs/skywebcam.jpg;
# convert image.jpg to 150kb for WUnderground
/share/bin/convert /share/htdocs/skywebcam.jpg -define jpeg:extent=150kb /share/htdocs/image.jpg;the camdata.txt is processed by mb to add the weather values (templates) you want as a layer on the image.
Regards Simon
https://www.conligwx.org/pws
