Particle data on AQICN.org
RLB77
Post by RLB77 »
Hi
Is it possible to use Meteobridge to upload PM25 data to AQICN.org? It seems a worthwhile project monitoring global pollution and a number of meteobrodge users will be collecting the relevant data.
Details of their data ingestion are here: https://aqicn.org/data-feed/templates/
And the main site is here: https://aqicn.org/contact/
All the best
R
Re: Particle data on AQICN.org
RLB77 wrote: Sat May 23, 2020 10:19 am Hi
All the best R
If I understand you correctly you ask MB "to upload PM25 data to AQICN.org"?
But AQICN.org does not accept uploads at all.
They will read your data from an URL you registered with them.
That URL should be pointing to a file of your measurement data on your own website.
Also they do only digest official stations
Note that the data published on the World Air Quality Index map is only official data provided by each country respective Environmental Protection Agency (see the full EPA list).
Exception:
If your country or city does not have official monitoring, it is acceptable to report data from more affordable instant air particle counters (eg PMS, SDS,..). While we do recommend to use the semi-professional GAIA air quality monitoring stations for this purpose, we, however, accept data from other stations. Nevertheless, such particle counter-based stations need to report enhanced data feed with additional quality controls (see quality control section).
RLB77
Post by RLB77 »
Thanks for this. Sorry for the waste of time.
