HTML generation. **solved**
Post by 36260 »
I'm currently running NANO HD Meteobridge 4.3 (May 14 2020, build 3057), FW 1.4 and trying to get HTML generation to create the expected file. HTML template is done and working (access by http://ip/cgi-bin/template.cgi?template ... plate.html works. In service tab, I create a new entry select HTML generation, select a template, put a file name, hit save, then test. I can't find any file in various folders (accessed with SMB).
What am I doing wrong?
Thank you
ConligWX
Re: HTML generation
Post by ConligWX »
the generated file has a filename of *.html yes?
then it should be in the \\ip.of.mb.nano\data\html\ folder
I just tested it, and thats where my file is created.
36260
Re: HTML generation
Post by 36260 »
Thanks ConligWX. Indeed I was expecting to get the file in that folder. Coming back to my PC, I had the surprise to see the file! So I don't understand what happened. Everything is fine.
ConligWX
Re: HTML generation
Post by ConligWX »
generation can take a few seconds - so just be patient.
36260
Re: HTML generation
Post by 36260 »
indeed. But I wait for sure. no worries.
