Blocking a sensor
wsnoordbergum
Blocking a sensor
Post by wsnoordbergum »
It is a very good feature to block a sensor in meteobridge on the live data page.
Just click the sensor and it is blocked.
This currently works and prevents data being sent to weather networks of the blocked sensor.
It would be a great improvement if the blocked sensor is also blocked (---) in the running services.
I had some bad data from my wind sensor, so I blocked the sensor wind0wind and wind0avgwind.
The wind data on my site however is not blocked as it is used in FTP upload and HTTP requests.
Is it possible to implement this so that the blocked tags are dashed out?
Would also be great during maintenance.....and to block wrong data while you're not home and can't immediately fix the problem.
