Display “%” in Twitter? **solved**
cphMichael
Post by cphMichael »
I use the Meteobridge Twitter service to display local weather data.
I use th0hum-act to display the outdoor humidity and would like to display a “%” after the sensor.
Meteobridge use the “%” as a modulus operator, so I haven’t figured out how to display it.
https://twitter.com/frbvejret
Re: Display “%” in Twitter?
cphMichael wrote: Fri Jun 26, 2020 8:08 pm I use the Meteobridge Twitter service to display local weather data.
You should use another character which looks like a % but it is not.
Answered here: viewtopic.php?f=56&t=13325
The big advantage of a forum is that most problems are already answered.
You find the discussions using the search box in the top right.
=> I entered "twitter percentage symbol"
cphMichael
Thank you very much for your reply. That solved it.
I will try the search next time :wink:
